This command deletes a key to add to a keychain.
| keychain_name | Specifies the name of the keychain. |
| delete | Specifies deleting a key from the keychain. |
| key | Authentication key entry. |
| key_id | Specifies the unique identifier within a keychain. Range is 1-65535. |
N/A
Use this command to delete a key from a configured keychain.
The following command deleetes a key:
configure keychain ospfv3-keys1 delete key 3
This command was first available in ExtremeXOS 31.3.
